None public RC-3 and RC-4 for choco package testing. The current RC-4 only works via Steam and direct download for now.
Window handling
Revert custom window handling changes from RC-1 and add Qt dark window navigation mode support. This is less buggy and also does not remove all window shortcuts and shadows.
Add explicit quit and minimize warning.
Windows
Fix windows wallpaper fade in calculation again. We know correctly calculate the default Windows wallpaper position for nice fade-in animations.
MacOS
Revert to 6.3.2 until WebEngine issues are resolved. See my bugreport here.
Fix Wallpaper showing app icon in dock.
Wizards
Add qml project file to QML Wallpaper. This will lets user easier edit QML Wallpaper via QtCreator
Widgets
Small icon and window handling fixes.
Development
Deprecate QtMaintanance based Qt setup. We now use aqt directly and thus no longer require a Qt account. If you are using VSCode you can simply install the C/C++ and CMake Tools with the newly added CMakePresets.json. QtCreator still has some issues, see my bugreport here.
Linux
Add working linux CI. This also includes a working KDE Wallpaper version that is not yet 100% ready.
