Greetings. I am searching, through lively or really anything not too shadey, a way to set up a live slide show of scrolling smaller images. Many slide shows and collage options are mutually exclusive, but I’m looking for something close to the functionality of Thisanimedoesnotexist.ai. Although even a static slide show that showed multiple random images would be fine. Can Screenplay do this? do you know of any way it can be done?
I hope this is the right spot. I am running windows 10 by the way
example image
_tmp_190837.zip (288.6 KB)
This is my first hardcoded version. Will try to improve it tomorrow after work ![]()
Simply extract this folder into
C:\Program Files (x86)\Steam\steamapps\workshop\content\672870
@scapegoat do you have an image set that I could use, so I better test this idea?
i’m also interested in this
